Hello
Recently I purchased the Evaluation board EVAL_3K3W_LLC_HB_CFD7 along with I got the source code of the board.
But when I am running the source code in the DAVE IDE it is giving error without change in the code. which I am unable to understand I searched this error on the internet but none of the ideas work to resolve the issue.
Here I am attaching the picture of the error. if anyone can help me to solve this
Error:- Description Resource Path Location Type
make: *** No rule to make target '../Dave/Generated/GLOBAL_HRPWM/global_hrpwm_conf.c', needed by 'Dave/Generated/GLOBAL_HRPWM/global_hrpwm_conf.o'. Stop. XMC42_LLC3k3W C/C++ Problem
Looking forward to hear from community
Ashwani
ispn:24821:1:0
l1:314:1:0
XMC
Hi @ashwani ,
I tried importing the zip file which had shared and I was able to build the project without any errors.
Can you try to import the zip file, generate code and then build the project and see if it builds without any errors at your end.
Hi @ashwani ,
Did you generate the code before building it?
Usually because you don't have a file available to make, you need to check that file exists or are you in the right directory for building.
Sometimes it caused by a spelling error, or forgot to include the directory in which the source file resides etc. Can you also check if your project was renamed or copied with new name?
Yes i have generated code before building it but still it is giving error and i m not getting what to do next ?
if you want i'll send you the source file if you can check it that'll be very helpful to me.
Please give me your mail id to send the file ?
Ashwani
can someone reply on this and suggest me the solution ?
Hi @ashwani ,
