User22557
I am currently using the XMC 2 GO kit and if i add the APP "ADC_MESUREMENT_0" and generate the code and build the project i always get an error ('XMC_VADC_GLOBAL_SHS_AREF_EXTERNAL_VDD_UPPER_RANGE' undeclared (first use in this function) and i can't solve it.
I am new with this microcontrollers so i have some dificulties. The error can be seen in the attached image and it is present in the library.
Can you help me please solving this error?
Vasanth
Hi Tiago Rocha,
Could you please try using the latest version of Dave ? You can install Infineon toolbox and download the latest version of Dave from there.
https://www.infineon.com/cms/en/tools/landing/infineontoolbox.html
Vasanth
Vasanth
Could you please share the code you are using so that we can try to recreate the issue at our end ? Also what is the app version you are using at your end ?(You can right click and check on properties)
Vasanth
User22557
Vasanth
I didn't change any code of main, it is the folowing:
#include //Declarations from DAVE Code Generation (includes SFR declaration)
* @brief main() - Application entry point
* Details of function
* This routine is the application entry point. It is invoked by the device startup code. It is responsible for
* invoking the APP initialization dispatcher routine - DAVE_Init() and hosting the place-holder for user application
* code.
DAVE_STATUS_t status;
if(status != DAVE_STATUS_SUCCESS)
/* Placeholder for error handler code. The while loop below can be replaced with an user error handler. */
while(1U)
/* Placeholder for user application code. The while loop below can be replaced with user application code. */
while(1U)
The Dave version is 4.4.2 and i made the updates of the library automatically.
I went to properties but i didn't found the version of the library .
Another problem that i have is that when i try to download in infineon website the latest version of XMC Lib or Dave APPs, it opens a new tab and quickly closes it and nothing happens.
In the "Help contents" i found this versions:
5342.attach
Vasanth
Hi Tiago Rocha,
Vasanth
User22557
Vasanth wrote:
Hi Tiago Rocha,
Vasanth
Thanks for trying to help. I think i found a solution. I've downloaded the latest version of XMC Lib, copy the files inside the folder XMCLib>inc and paste inside the folder inc of the project [Project name]>Libraries>XMCLib>inc. The problem of this is that i will have to make this procedure every time i create a new project.
Best Regards
Tiago Rocha
Vasanth
Hi Tiago,
Happy to know that the issue is resolved.
Vasanth
