Odri
First solution authored Welcome! 5 replies posted
I am creating a project for the XMC1302 microcontroller with Keil and I don't know how to solve the following error:
.\Objects\prueba.axf: Error: L6218E: Undefined symbol Image$$ARM_LIB_STACK$$ZI$$Limit (referred from startup_xmc1300.o).
In "Manage Run-Time environment" I have added the following packages:
Device -> Startup
CMSIS -> Core
Kind regards,
Xabi
Odri
Good morning,
After these steps I still got the same error.
I was able to solve it by changing the file "startup_XMC1300.s". I had saved a previous version and I have based on it to run version 3.0.0, which is the current one.
Kind regards,
Xabi
Vasanth
Hi Xabi,
Could you confirm that you have installed the DFP for XMC from the following webpage: https://www.keil.com/dd2/pack/
After installing, restart Keil to confirm whether the issue still persists.
Vasanth
Odri
Good morning,
Kind regards,
Xabi
Vasanth
Hi Xabi,
Thanks for sharing the solution with the community. This will be helpful for other community members facing the same issue.
Vasanth
Odri
Hi Vasanth,
I attach the startup I am currently using with the XMC1302 microcontroller.
Kind regards,
Xabi
