Pavel_47
I'm looking for a simple solution to convert microphone audio to S/PDIF stream.
Does Infineon have products in its portfolio to achieve this functionality?
Pavel.
sujatapatil
10 likes received 100 sign-ins 25 solutions authored
Hi ,
It is not possible direct but as i suggested in my previous response you need to interface external S/PDIF
Sujata
sujatapatil
XMC series does not have single solution for S/PDIF format but you can use PSOC creator for this solution . Below is link for S/PDIF transreceiver and example code .
https://www.infineon.com/cms/en/design-support/tools/sdk/psoc-software/psoc-3-5-components/s-pdif-tr...
code example
https://www.infineon.com/cms/en/search.html#!term=s%2Fpdif&view=all
Hope this will help you .
Sujata
sujatapatil
Hi ,
I have not heard from you since my response. I assume that this is because the issue is resolved and you are busy with other important work.
If, however, the issue is not resolved, please do let me know and I shall work with you to ensure that the issue is resolved.
I will wait for another two days to hear from you. If I do not hear from you, I shall go ahead and close this case.
You can always reopen this case or create a new case for any other issue. We will be happy to help you in resolving your issues.
Thanks and Regards,
sujata
Pavel_47
Is it possible to realize with any XMC device the following transform:
input1: digital micro
output1: S/PDIF
input2: S/PDIF
output2: speaker
sujatapatil
Hi ,
Sujata
sujatapatil
Hi ,
Sujata
The issue is reolved using stuff of other manufacturers.
