LiZJ
5 sign-ins First solution authored First reply posted
#EVAL_3K3W_TP_PFC_SIC# testing environment
1、Switch to the inverter mode;
2、The AC terminal is connected to a resistive load(not connected to the ac grid-connected simulator);
3、DC terminal input 400VDC;
Test result:The AC end has no AC230V voltage output;
Question:Whether this demo board  does not work properly with the default  software in the test environment above? How can I get the software version that supports the above test environment?
Owen_Su
250 solutions authored 500 replies posted 50 likes received
Hi, @LiZJ ,
    We will have internal discussion and then feedback to you. And I found that you have created a thread yesterday, the same question should discuss in one place, so I will close this one and keep our discussion in the previous one. Thanks for your understanding.
https://community.infineon.com/t5/XMC/EVAL-3K3W-TP-PFC-SIC-%E9%80%86%E5%8F%98%E6%A8%A1%E5%BC%8F%E6%9...
BR,
Owen
Owen_Su
Hi, @LiZJ ,
BR,
Owen
