09:34 AM
Mar 18, 2016
09:34 AM
we are being evaluated for the passage of our platforms Spansion 16FX family in infineon in xmc4500 family suggested by EBV italy and
against our will see that it is released implementer configuration Ebu in case you have to do with the type of sram memories, nor, external
bus interface display (with integrated controller) I would like to stimulate the technical department to release an application note that
can guide us in a simple configuration of the device (in xmc library EBU config file) for us is essential to have a configuration suggested
by infineon is strange as I read in the forum that is not planned for you should be the work of a day we need your kind support if we start
working together for us would be a pleasure
Mar 20, 2016
08:23 PM
Mar 20, 2016
08:23 PM
08:15 AM
Mar 21, 2016
08:15 AM
No it is an example for a dynamic ram would serve an example for a static ram for example with 8-16 bit bus
08:23 AM
Mar 21, 2016
08:23 AM
example tft with intergate tft controller bus 16bit
