Is it possible to configure the XMC4800 with both EtherCAT and an EBU? There appears to be a conflict. If so, can someone point me to how best to do it? There doesn't appear to be an EBU APP in Dave.
I would like to use a multiplexed bus to communicate with an FPGA.
Thanks!
jferreira
10 sign-ins 5 sign-ins First like received
Which package are you targeting?
If you use the LFBGA-196 you will be able to use both EBU and ECAT simultaneously.
See https://www.infineon.com/cms/en/product/evaluation-boards/kit_xmc48_aut_base_v2/
