I'm currently using an XMC4400 F64K512, which one should I use, DaveIDE or ModusToolbox?
- DaveIDE
- modustoolbox
Hi @Myshelter ,
Greetings from Infineon.
We support Modus Toolbox in future so we recommend you to use Modus Toolbox.
You need to follow some steps while using ModusToolbox:
1)When creating a new application select KIT_XMC_PLT2GO_XMC4400
2)Now go to the Tools, under Tools select BSP Assistant here you can change the target device to XMC4400 F64K512
Hope this helps and kindly let me know if you need any further information.
Best Regards
Pradeep.
Hi @Myshelter ,
Best Regards
Pradeep.
Hi @Myshelter ,
I have seen you have created another duplicate thread (modus ToolBox )which is being handled by my colleague. In order to avoid duplicates I am closing this thread so that you can continue your discussion there.
Best Regards
Pradeep.
