I run a PWM named PWM_Out and like to connect variuos Interrupt Apps to PWM_OUT. Connecting one to the compare match event failed. Periode and compare match are enabled.
In table 23.2 of the ref manual it is stated: 4 service request lines available. I want to use the fourth line.
See what I 've got: Screen shot & solver log are attached
Any idea where to look? The solver message isn't very helpfull.
Kind regards
Kurt
P.S Problem solved by recreation of the entire project. No response from Infineon
