funkyluke
5 sign-ins First like received 10 replies posted
I would like to build an application that outputs DSD results through the internal DAC.
But the DAC input stages only take 12-Bit inputs while the DSD only produces 16 bit results -> the 4 MSBs would be cut off.
Is there any way around this that does not involve manually bit-shifting each result?
The DAC has a SCALE and MULDIV input, but this only takes 12-bit inputs ...
Any Ideas?
Funky Luke
