Rhohentanner
Hi, I'm using a XMC4108 processor and want to generate an interrupt when I receive CAN RTR frames. I have this working, but for some reason I need to constantly set the DIR bit of the CAN receive Object or it will reset on its own almost immediately after setting it. I am using CAN_NODE_MO_ClearStatus(HandlePtr1->lmobj_ptr[2], XMC_CAN_MO_SET_STATUS_RX_ENABLE | XMC_CAN_MO_SET_STATUS_MESSAGE_DIRECTION); to set the DIR pin, am I doing that correctly or is there a better more correct way of doing it so I don't to make the call over and over?
Thanks, Rob
sujatapatil
250 replies posted 50 solutions authored 10 likes received
Hi Rob,
It looks good as for each Transmit request DIR bit will be confirmed.
Sujata
sujatapatil
Hi Rob,
Sujata
