XMC™ Forum Discussions
everytime I try to connect to the example server (OPCUASERVER_LWIP_XMC47) I get a timeout exception. I only changed the IP, netmask and gateway adresses in main.h as described in the user manual.
The error occurs in function opcua_recv (opcua_server_tcpip.c) when calling UAServer_New_data_received.
It seems like the program runs into an infinite loop when calling this function for the third time. The first two times the function is called there are no errors and it returns OpcUa_Good.
I use the client which is included in the OPC Foundation´s .NET Stack and the XMC4700 Relax Kit.
Has anybody encountered a similiar problem?
jferreira
First like received 750 replies posted 500 replies posted
We are looking into the problem. We will keep you posted with any news.
jferreira
A new version of the OPC UA Server from Matrikon is available.
Go to the DAVE Example Projects download page, use OPC as keyword and download and import the project into DAVE.
You can also access the examples inside DAVE, menu button Help>Install DAVE APP/Example/Device Library… , select in Examples and search for OPC.
To connect to the development board you can use the Sample client from the OPC Foundation
