DAVE 4.5.0 snprintf issue
12d6k
Hello, I try to display the temperature (int16_t and float) on my OLED.
with int:
char buff[64];
rawTemp = ((int32_t)daten[0] << 12) | ((int32_t)daten[1] << 4);
int_16t temp_i = temp_int(rawTemp);
float temp_f = temp_float(rawTemp);
ssd1306_Fill(Black);
snprintf(buff, sizeof(buff), "%02d", temp_i);
ssd1306_SetCursor(30, 26);
ssd1306_WriteString(buff, Font_16x26, White);
ssd1306_UpdateScreen();
and with float:
char buff[64];
snprintf(buff, sizeof(buff), "%f", temp_f);
I can see the digits on my OLED when I use the int variant. When I use the float variant I can't see. I checked the buff in debug and the buff is empty. Why is it empty? What am I doing wrong?
sujatapatil
50 solutions authored 10 likes received 100 sign-ins
Hi ,
 replace with
sprintf(buff, "%f", temp_f)
And also double the size of buffer as float number will be stored different (IEEE standard)
than integer or character. Your buffer size is not enough to store it . try with 1 /2 bit precision and adjust buffer .
sujatapatil
Hi ,
Please use sprintf instead snprintf .
Sujata
sujatapatil
Hi ,
I hope you received my last response. Hope it worked for you.
Sujata
12d6k
Hi, sorry for my late reply.
Same result with sprintf 😪
sujatapatil
Hi ,
 replace with
sujatapatil
Hi
Hi ,
I have not heard from you since my response . I assume that this is because the issue is resolved and you are busy with other important work.
If, however, the issue is not resolved, please do let me know and I shall work with you to ensure that the issue is resolved.
I will wait for another two days to hear from you. If I do not hear from you, I shall go ahead and close this case.
You can always reopen this case or create a new case for any other issue. We will be happy to help you in resolving your issues.
Sujata
