Question 1.
On the Infineon website, I found below.
https://infineoncommunity.com/2018Mar_GLOB_GATED_DALI_Software_ID941
But Our customer wants DALI IEC 62386-209. Do you have any plans to update this library.
Question 2.
I heard from a customer that the MCU clock accuracy to implement the DALI library should be within 1%.
The XMC1300 is also included as a target device for this library, but the clock accuracy for this device appears to be over 1%.
Can XMC1300 series satisfy the DALI specification?
XMC
- dali
Regarding question 2)
There is a procedure to calibrate to internal clock for higher accuracy. Could you please kindly refer https://community.infineon.com/t5/XMC/Application-Note-XMC1000-Oscillator-handling/m-p/320778
Vasanth
Vasanth
Regarding 1 st question, we have forwarded the request internally. I will update you if any plans on update are decided.
Vasanth
