NXTY_Inoue
Distributor - NEXTY (Japan)
First like given First like received 10 replies posted
I would like to confirm about DALI library.
I found "DALICG_AX209.c" and "DALICG_AX207.c" in the files downloaded from URL below.
https://infineoncommunity.com/2018Mar_GLOB_GATED_DALI_Software_ID941?_gl=1*sqxjp7*_ga*NTI1MjcxMDE1Lj....
Does this library now support IEC 62386-207 and IEC 62386-209?
If not yet, I would like to know the update plan.
Aashita_R
50 likes received 100 solutions authored 250 replies posted
Hi @NXTY_Inoue ,
I downloaded DAL Software code example from here : https://infineoncommunity.com/2018Mar_GLOB_GATED_DALI_Software_ID941. I found the document in the zip file where the following information was mentioned-
I am attaching the document here for your reference. I hope this helps.
Aashita
Pradeep_PN
250 sign-ins 100 solutions authored 25 likes received
Hi @NXTY_Inoue ,
We are discussing your query with the internal team and will get back to you as soon as I received the answer.
Best Regards
Pradeep.
Aashita_R
Hi @NXTY_Inoue ,
Aashita
