01:30 AM
Dec 16, 2015
01:30 AM
I am about to start a new uC project with a XMC 4500 Relax kit!
I want to measure the current and voltage (output and input) of a powerplant.
For voltage measuring, i'll need 6 ADCs
* battery voltage of my gelsolarbatteries
* charging voltage of my solar charging modules from each my of two panels
* charging voltage of the DC windturbine
* external battery charging voltage
* 12V AC/DC converter powersupply voltage
for current measuring i'll need another 6 ADCs
* load current of my batteries
* charging current from each of my two solarchargingmodules
* charging current of my windturbine
* external battery charging current
* 12V AC/DC converter load current
I also want to swith I/O Pins with a connected powerrelay/mosfet or regulate some voltagelevels via PWM and powermosfets
Has anyone some good working resistors or shunts used with a board like this becouse that will spare me some searchingtime online!
I do want to display the measured values on a homepage wich I want to access from my home network. Data should be collected to draw some weekly diagrams and send them to my mail adress. Do you think I am able to get this to run?
Switching all the I/Os should also be possible from this homepage to manually controll this "powerplant".
Some basic infomation at the end: voltage levels from 0-20V DC max
Currents up to 40Amps DC max
12:21 AM
Dec 23, 2015
12:21 AM
I might not be able to help you on the hardware design. But I can advise you on the ADC and Ethernet which you can display the measured values on a home page.
Best Regards
Travis
Best Regards
Travis
03:36 AM
Jan 06, 2016
03:36 AM
I was doing some adc examples but i recogniced that the ADC apps only work if ure in the environment of a infineon example program if i start my own infineon projekt the Apps just dont work is there any solution or can u show me how to program the adc without the aps couse the webserver app isnt working on dave 4 right now right? So ill use dave 3 and i want to write the code without apps
Jan 06, 2016
07:15 PM
Jan 06, 2016
07:15 PM
U can refer to this example which is using the low level drivers.
http://www.infineonforums.com/threads/3373-XMC4000_HOT-How-to-do-VADC-Queue-source-synchronous-conve...
