User8683
Level 4
Level 4
First like received
Can someone please direct me to the code that goes with application note AP32346. (https://www.infineon.com/dgdl/Infineon-ApplicationNote_XMC1000_Software_Update_IIC-AN-v01_00-EN.pdf?...)
My attempts to find through google keep showing "Page not found" responses.
Also please fix the links to the source.
Jason
DRubeša
Hi Jason,
I believe you are searching something like this:
https://www.infineon.com/dgdl/Infineon-Software_update_IIC-AN-v01_00-EN.zip?fileId=5546d46257fa4a9c0...
This is located under "Documents" section of XMC1000 product family. XMC1000 Document section
Deni
User8683
Level 4
Level 4
First like received
Thank you. Hopefully the Infineon documentation folks can add the link in the document for other folks.
Cheers,
Jason
