Rakesh_rp
First solution authored 10 replies posted 10 questions asked
hi,
I am using xmc1400 boot kit  .  I  changed BMI  using function   XMC_SCU_SETBMI()   to  ASC Bootstrap Loader Start-up Mode .
Now I am not able to flash my code . In the console it is showing target not connected . How to reset the  BMI ?
Vasanth
In configurations tab go to "Set Up", select Segger as debug type. Select SWD and try changing the BMI(after connecting the device).
Vasanth
Vasanth
The BMI value can be changed using multiple methods. One is through changing it through Dave, BMI Set and Get tool.
that will open the tool for you,
Other way is to use XMCFlasher,
In the BMI option there, you can select the BMI Get Set
Additionally you can use BMI get and set in JLINK commander or update the BMI using ASCBSL bootloader if your application requires that. These are the different methods to change the BMI.
Vasanth
Thanks for replying,
I tried to use XMC flasher to change BMI . I am using jlink segger debugger software tool.  How to resolve the issue shown below
Rakesh
Vasanth
Vasanth
I am not able to  change the debug type . I can select only DAP
