XMC™ Forum Discussions
gachetp
10 replies posted 25 sign-ins 10 questions asked
hello,
I would like to calculate the stack usage of my project so I use this function which is already use in an other porject.
void StackMonitor_Init(void)
uint32_t u32StackSize = (uint32_t)&stack_size; // Pointer Address
uint32_t u32StackInit = (uint32_t)(&__stack_start); // Pointer Address
uint32_t *pu32SP = (uint32_t *)__get_MSP(); // Current Main Stack Pointer
pu32SP -= 5; // Make sure I'll not overwrite real data
sp32MaxSP = pu32SP;
while ((uint32_t)pu32SP > (u32StackInit - u32StackSize))
*pu32SP = 0xC0C0C0C0U;
pu32SP--;
I have an handler which appears when I come out of my while.
I don't know to do that.
If someone can help me, it will be very nice.
Pierre Gachet.
Vasanth
Hi Pierre,
1. if you have hard fault check registers CFSR, SHCSR, BFAR, MMFAR and from those try to understand what is happening, you can examine also registers that are pushed on stack
2. enable also other fault handlers, this makes easier to detect the cause
3. read following document http://www.keil.com/appnotes/files/apnt209.pdf on how to work with handlers, there are several similar you can find on internet.
Vasanth
Vasanth
Hi Pierre,
Are you telling that your control is going to a hanlder while you are trying to runt the code ? Did you try to identify the handler being triggered and read the registers on the time of failure?
Vasanth
Hello Vsanth,
thank you for your reponse. I don't know how to do that. How can I identify the handler, registers on the time of failure ?
Already thank you,
Pierre
Vasanth
Hi Pierre,
Vasanth
