05:08 AM
Jul 12, 2016
05:08 AM
Used version of COMP_REF app V. 4.1.4
Target XMC1302-T038x0032
Settings:
Selected reference source CCU4 for generation of reference voltage
other settings: Filter used, Inverter activated; ERU used, Hysteresis = 20 mV
what happens
Generation of Reference Voltage not working; no PWM signal on CCU4 output pin due to erroneous source code generation
Solution
Manually edit "comp_ref_conf.c"
Line 87:
Change
.ref_source = COMP_REF_SOURCE_BCCU,
to
.ref_source = COMP_REF_SOURCE_CCU4,
Settings:
what happens
Solution
Line 87:
Change
to
Labels
01:37 AM
Jul 21, 2016
01:37 AM
In my case it is working. Did you select the CCU4 as source in the GUI and then pressed again code generation button?
10:29 PM
Jul 21, 2016
10:29 PM
Hi Jesus
I saw in my settings that i selected the wrong target
XMC1301-T038x0032 instead of XMC1302-T038x0032
now it is working correctly
Thanks for your help
Martin
Martin
