CCU8 SW capture
I wonder if it is possible to trigger a capture by a software in the CCU8 modules? As far as I understand the only way to trigger a capture is possible through CCcapt0 and CCcapt1lines that are controlled by HW. I know that one can map the SCU start event (CCUCON) to CCcapt0 and CCcapt1but in my case I will need this for other purposes.
Mariusz
Yes, You can also trigger a capture using sotware. You can use CC8yINS for this.
One way to trigger the capture unit using ERU function. Just map ERU event to the CC8yINS using connection matrix.
Hi Naresh,
thank you for this suggestion. I was hoping that maybe it is possible to fire capture without involving other peripherals. It seems that not.
Best,
Mariusz
