Aug 11, 2017
12:26 AM
Aug 11, 2017
12:26 AM
I am trying to understand how to use the Multi Channel Feature of the CCU8 to control 3 PWM Outputs.
In all the examples I have found the PWM is shown as either high, low or toggling. How can the three states be controlled with one bit?
The reference Manual Shows the following example:
In this example the multi channel pattern does not Change between step 2 and 3, but the PWM Outputs do change. I do not understand this!
Any help on understanding the Manual would be most appreciated.
