Dear Receiver,
I would like to build a XMC4500 project but I met the following error message.
It says "system can't find specified path". You could also check the attached file.
Could you please help to check this problem ?! Thank you so much.
'Building file: ../Startup/startup_XMC4500.S'
系統找不到指定的路徑。
make: *** [Startup/startup_XMC4500.o] Error 1
make: *** Waiting for unfinished jobs....
Startup/subdir.mk:25: recipe for target 'Startup/startup_XMC4500.o' failed
系統找不到指定的路徑。
'Building file: ../Startup/system_XMC4500.c'
make: *** [Startup/system_XMC4500.o] Error 1
Startup/subdir.mk:31: recipe for target 'Startup/system_XMC4500.o' failed
XMC
Hi Tim,
Could you please make sure that you have selected the right device in the project ?
Vasanth
Hi Tim,
Vasanth
