User8651
Hi all,
I found a bug in CPU_CTRL_XMC4 App (all versions) about the settings of FLASH wait states for XMC4300:
At first lines the define is incomplete:
#if ((UC_SERIES == XMC48) || (UC_SERIES == XMC47))
#define PMU_FLASH_WS (0x4U)
#elif ((UC_SERIES == XMC45) || (UC_SERIES == XMC44))
#define PMU_FLASH_WS (0x3U)
#else
#define PMU_FLASH_WS (0x2U)
#endif
shoud be:
#if ((UC_SERIES == XMC48) || (UC_SERIES == XMC47) || (UC_SERIES == XMC43))
#else
#endif
Otherwise any XMC4300 projects will run with only 2WS (as for XMC4100-4200 running at 80Mhz) and this will lead to unpredictable results. The software could run on some devices, and on others would fail.
Andrea Taglietti
jferreira
5 sign-ins First like received 750 replies posted
Thanks for reporting the issue.
We will fix it in the up coming release.
