Bond_007
10 questions asked 25 sign-ins 10 replies posted
Hi Team,
We are working on a Sensorless FOC project to run the BLDC Motor. We are unable to run the motor with the project  "PMSM_FOC_SL_XMC13_PUBBLIC_V1_5_8_LIB". As we have done with the Hall sensor project. We were in the middle of testing the FOC project and were stuck with this project. Now, we need support for the motor we are using now.
https://in.rsdelivers.com/product/rs-pro/rs-pro-brushless-24-v-019-nm-4000-rpm-5mm-shaft/5366024
Can anyone be available for remote support to configure and run our motor?
We will be very thankful. If we get the support we are seeking for...
Thanks & Regards
Vamshi
Krupashankar
250 solutions authored 500 replies posted 50 likes received
Hi @Bond_007,
Can you please follow the steps mentioned in the document: PMSM_FOC_SENSORLESS_Getting_Started_v1_5.pdf
If the above steps didn't solve your problem please let us know the exact problem. This will help us to give a suitable solution.
Krupashankar
Krupashankar
Hi @Bond_007,
Krupashankar
