04:30 AM
Mar 11, 2016
04:30 AM
My name is chethan kumar recently i brought XMC1400 Boot Kit for bldc motor control application using PMSM_FOC app. This app only available for XMC1300 series,
so did below mentioned procedure
1. i configure and generate the FOC code as per our BLDC motor in XMC1300 series created project.
2. Generated library files pasted to XMC1400 series project.
3. changed the pin mapping.
Here i got error in PMSM_FOC_ADCconfig, it is only for XMC13.
I don't know this is right or wrong because i am new to infineon controllers, kindly suggest me how to configure in XMC1400 series.
Chethan kumar
Chethan kumar
12:40 AM
Mar 21, 2016
12:40 AM
Hi Chethan,
There are some updates to the CCU hardware in XMC1400 and is slightly different from XMC1300. Therefore, we cannot directly paste the code to a XMC1400 series project.
Currently, there is no plan to update the PMSM_FOC APP to support XMC1400. This APP only supports XMC1300.
Could you try to get a XMC1300 series board to try with the PMSM_FOC APP.
Daryl
Daryl
