NXTY_Inoue
Distributor - NEXTY (Japan)
50 sign-ins 5 replies posted 10 questions asked
I would like to know whether I can implement Azure RTOS on XMC4000 series.
Can XMC work with Azure RTOS even if XMC is not MS hardware partner device?
Vasanth
Hi ,
This has not been tested and confirmed yet. There are FreeRTOS ports implemented in XMC. You can check the following if you are interested.
1. https://www.freertos.org/Infineon-ARM-Cortex-M4-XMC4000-RTOS.html
2.https://github.com/Infineon/mtb-example-xmc-blinky-freertos
3. https://docs.aws.amazon.com/freertos/latest/userguide/getting_started_infineon.html
Meanwhile if there are any device specification wise requirement for porting, we can provide more clarity on that.
Vasanth
Vasanth
Hi ,
Vasanth
