User7457
First like received
Hi ,
where can I find all differences between xmc4500 cores AA AB AC ?
Frank
Hi Frank,
There is no particular document to list the different between the devices.
But you can refers to the Errata Sheet to find out what are the different.
If a certain issue found in AA device and fixed in AB, the issue will be listed in AA errata sheet but not in AB Errata Sheet.
Hence, you can find the differences of the devices.
User5581
Is there a register than can be read (similar to the CPUID register) that firmware can use to know the version
stepping of the host device?
Travis
First like received
Oh, Yes. Pls see attachment.
User5581
That's exactly what I was looking for. Thank you!
