wsnfly
First solution authored 10 replies posted 25 sign-ins
An error occurred when compiling a project from many years ago. This problem occurs in many projects. I don’t know how to solve it.
19:39:24 **** Build of configuration Release for project sihekou_XMC1302-T038x0016_0 ****
"\"D:\\soft\\dave\\4.5.0.202105191637\\eclipse\\ARM-GCC-49\\bin\\make\"" --output-sync -j12 all
'Building file: ../Libraries/XMCLib/src/xmc1_eru.c'
In file included from C:/Users/wangs/Desktop/20211001-dave/sihekou_XMC1302-T038x0016_0/Libraries/XMCLib/inc/xmc_common.h:76:0,
'Invoking: ARM-GCC C Compiler'
from C:/Users/wangs/Desktop/20211001-dave/sihekou_XMC1302-T038x0016_0/Libraries/XMCLib/inc/xmc_eru.h:62,
"D:/soft/dave/4.5.0.202105191637/eclipse/ARM-GCC-49/bin/arm-none-eabi-gcc" -MMD -MT "Libraries/XMCLib/src/xmc1_eru.o" -I"C:/Users/wangs/Desktop/20211001-dave/sihekou_XMC1302-T038x0016_0/Libraries/XMCLib/inc" -I"C:/Users/wangs/Desktop/20211001-dave/sihekou_XMC1302-T038x0016_0/Libraries/CMSIS/Include" -I"C:/Users/wangs/Desktop/20211001-dave/sihekou_XMC1302-T038x0016_0/Libraries/CMSIS/Infineon/XMC1300_series/Include" -I"C:/Users/wangs/Desktop/20211001-dave/sihekou_XMC1302-T038x0016_0" -I"C:/Users/wangs/Desktop/20211001-dave/sihekou_XMC1302-T038x0016_0/Dave/Generated" -I"C:/Users/wangs/Desktop/20211001-dave/sihekou_XMC1302-T038x0016_0/Libraries" -Os -ffunction-sections -fdata-sections -Wall -std=gnu99 -Wa,-adhlns="Libraries/XMCLib/src/xmc1_eru.o.lst" -pipe -c -fmessage-length=0 -MMD -MP -MF"Libraries/XMCLib/src/xmc1_eru.d" -MT"Libraries/XMCLib/src/xmc1_eru.d Libraries/XMCLib/src/xmc1_eru.o" -mcpu=cortex-m0 -mthumb -o "Libraries/XMCLib/src/xmc1_eru.o" "../Libraries/XMCLib/src/xmc1_eru.c"
from ../Libraries/XMCLib/src/xmc1_eru.c:45:
Libraries/XMCLib/src/subdir.mk:93: recipe for target 'Libraries/XMCLib/src/xmc1_eru.o' failed
C:/Users/wangs/Desktop/20211001-dave/sihekou_XMC1302-T038x0016_0/Libraries/XMCLib/inc/xmc_device.h:1455:2: error: #error "xmc_device.h: device not supported"
'Building file: ../Libraries/XMCLib/src/xmc1_flash.c'
wsnfly
I solved the problem, changed the model of the microcontroller, and then changed it back. In this way, DAVE created the project twice and solved the original "unsupported hardware".
Pradeep_PN
50 likes received 250 sign-ins 100 solutions authored
Hi @wsnfly ,
Which version of DAVE are you using at your end ? I can see from your console you are using V4.5 Please confirm this.
I have imported your project at my end and tested this and it is working without any issues, Please refer to the below figure.
I am using the latest version of DAVE V4.5 .
Best Regards
Pradeep.
wsnfly
wsnfly
