u-s
Level 4
Level 4
50 sign-ins 25 replies posted First like received
I wold like to select an external oscillator for XMC4800 device.
I want to use the DSX321G with the following specification.
https://www.kds.info/product/dsx321g/
3992.attach
My application is ESC controller for robot.
Could you tell me if this oscillator can satisfy this application?
MichaelIFX
50 replies posted 25 replies posted 10 replies posted
According BECKHOFF specification in regard to clock supply for PHY connection the initial PHY clock source has to be 25ppm or better:
https://download.beckhoff.com/download/Document/io/ethercat-development-products/an_phy_selection_gu...
"3.2 Clock supply
The initial accuracy at room temperature of the PHY clock source has to be 25 ppm or better. This enables
FIFO size reduction, i.e., forwarding delay reduction, and supports fast DC locking."
