07:53 AM
Mar 10, 2016
07:53 AM
Hi All,
Is it possible in data reduction mode to have more than 4 samples? Or is that a hard limit? Could one somehow use the fifo to trigger a interrupt when it is full and then read out all the data, this should increase the number of samples one can take right?
regards,
Enigma
regards,
Enigma
06:32 PM
Mar 10, 2016
06:32 PM
Max, is 4 result values.
Sorry that the FIFO does not behave this way (disappointed :(). If I remembered correctly, every result received will triggered an interrupt.
http://www.infineonforums.com/threads/3781-XMC-4500-VADC-how-use-the-FIFO-buffer-to-reduce-the-CPU-l...
