Hi All,
I seem not to follow the reference manual very well (16-40 to 16-43) on the ADC conversion times.
First the example on 16-42. Does this mean it takes 1000ns to measure and have a result available for a single channel on a single S&H block? What is the 2nd conversion mentioned?
I would like to know something simple. Assuming I am using two analog input supplied to the two different S&H blocks. What is the fastest conversion time I can achieve if I read a single value out and how long would it take to read out both values?
I would appreciate any clarity someone can give me on this.
Enigma
Travis
First solution authored Welcome! 500 replies posted
The conversion time is as described below.
1780.attach
Hi Travis,
So this is the absolute timing for a conversion, no matter the amount of channels you sample? Does this mean in the XMC1300 if I have 8 analog signals connected I can sample all of them within 1us, thus every 1us I have 8 results? Or does it mean every 8us I have 8 results? This is where my confusion is.
Enigma
Travis
This is for XMC4500 VADC, whereas the XMC1000 have a different one.
The max sampling rate of an XMC1300 is 1MSamples/sec at for 12-bit samples, which is ~1uSec per channel. 8 Channels would essentially require a minimum of 8uSecs.
Hi smays,
Thanks for reading my question and answering it.
Enigma
