I'v just got a project for control 600W BLDC Motor.
I am new to use Infineon, DAVE.. and 750W + XMC1300 Kit is ready.
So My question is
1. What App should I use? If I want to run BLDC motor with 3 Hall sensor. BLDCBCH03? PMSMFOCSL02? BLDCBCSL01?
2. Where can I find example source for XMC1300 using BLDCBCH03?
3. Is there description of Apps?
Hi JK_Blue,
You can refer to the Getting Motor Control Application Kit Getting Started with BLDC Motor Block Commutation 3 Hall Sensor App
- http://www.infineon.com/dgdlc/en?dcId=8a8181663431cb50013431cb500b0000&downloadTitle=BLDC_Motor_BCH0...
( More materials at: http://www.infineon.com/cms/en/product/evaluation-boards/KIT_XMC1X_AK_MOTOR_001/productType.html?pro... )
- Link to DAVE v3 example ( http://www.infineon.com/cms/en/product/promopages/aim-mc/DAVE_3_Support_Portal/DAVE_Example_Project_... )
- APP description can be found from too Help->Help Contents. The list of DAVE Apps description can be found in the subject DAVE Apps.
Daryl
