Translation_Bot
嗨,
我用的是xmc7200,串口配置和寫入不知道哪裡寫錯了, CAN 無法進入中斷 CAN 無法接收數據。
最好的問候
5 回應
Translation_Bot
1:據我了解,這個問題會導致中斷配置。
2:我給你關於 M7 uart 中斷配置的代碼片段:
/* Populate configuration structure (code specific for CM4) */
cy_stc_sysint_t uartIntrConfig =
    .intrsrc=((NvicMux3_IRQn << 16) | UART3_IRQ),
    .intrPriority = 7,
 /* Hook interrupt service routine and enable interrupt */
		(void) Cy_SysInt_Init(&uartIntrConfig, &UART_Isr);
		NVIC_ClearPendingIRQ((IRQn_Type)uartIntrConfig.intrSrc);
		NVIC_EnableIRQ(NvicMux3_IRQn);
例如,我給你一個代碼示例,它 CAN 在 rx 中斷中獲取 rx fifo 值。
void UART_Isr(void)
	 if((UART3_HW->INTR_RX_MASKED & SCB_INTR_RX_MASKED_NOT_EMPTY_Msk ) != 0)
		 UART3_HW->INTR_RX = UART3_HW->INTR_RX & SCB_INTR_RX_NOT_EMPTY_Msk;
		uint32_t rec_data5 = Cy_SCB_UART_Get(SCB3);
		     //	cyhal_uart_putc(&cy_retarget_io_uart_obj,rec_data+1);
		 Cy_SCB_UART_Put(SCB3,rec_data5);
3:相關文件為:
https://www.infineon.com/dgdl/Infineon-AN234226_-_XMC7000_MCU_Usage_of_Interrupts-ApplicationNotes-v...
4:測試代碼在附件中。 專注於主。C, 我使用低級API,您 CAN 使用我的項目來實現您的功能,然後下一步調試您遇到的問題。
0
Translation_Bot
我 CAN使用MTB3.1導入您的項目,按照您的配置我仍然 CAN滿足要求。 我 CAN 在使用 MTB3.0 時導入您的項目,但 CAN運行它並出現錯誤。
0
Translation_Bot
嗨,
我的配置和程序如下,請大家幫我看看哪裡出錯了,我的中斷函數 CAN 進入。
最好的問候
0
Translation_Bot
您好,
* File Name: main.c
* Description: This example demonstrates the UART transmit and receive
*              operation using HAL APIs
* Related Document: See Readme.md
* Copyright 2019-2023, Cypress Semiconductor Corporation (an Infineon company) or
* an affiliate of Cypress Semiconductor Corporation.  All rights reserved.
* This software, including source code, documentation and related
* materials ("Software") is owned by Cypress Semiconductor Corporation
* or one of its affiliates ("Cypress") and is protected by and subject to
* worldwide patent protection (United States and foreign),
* United States copyright laws and international treaty provisions.
* Therefore, you may use this Software only as provided in the license
* agreement accompanying the software package from which you
* obtained this Software ("EULA").
* If no EULA applies, Cypress hereby grants you a personal, non-exclusive,
* non-transferable license to copy, modify, and compile the Software
* source code solely for use in connection with Cypress's
* integrated circuit products.  Any reproduction, modification, translation,
* compilation, or representation of this Software except as specified
* above is prohibited without the express written permission of Cypress.
* Disclaimer: THIS SOFTWARE IS PROVIDED AS-IS, WITH NO WARRANTY OF ANY KIND,
* EXPRESS OR IMPLIED, INCLUDING, BUT NOT LIMITED TO, NONINFRINGEMENT, IMPLIED
* WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE. Cypress
* reserves the right to make changes to the Software without notice. Cypress
* does not assume any liability arising out of the application or use of the
* Software or any product or circuit described in the Software. Cypress does
* not authorize its products for use in any products where a malfunction or
* failure of the Cypress product may reasonably be expected to result in
* significant property damage, injury or death ("High Risk Product"). By
* including Cypress's product in a High Risk Product, the manufacturer
* of such system or application assumes all risk of such use and in doing
* so agrees to indemnify Cypress against all liability.
#include "cyhal.h"
#include "cybsp.h"
#include "cy_retarget_io.h"
#include "cy_pdl.h"
* Function Name: handle_error
* Summary:
* User defined error handling function.
* Parameters:
*  void
* Return:
*  void
void handle_error(void)
     /* Disable all interrupts. */
    __disable_irq();
    CY_ASSERT(0);
* Function Name: main
* Summary:
* This is the main function.
* Reads one byte from the serial terminal and echoes back the read byte.
* Parameters:
*  void
* Return:
*  int
/* Assign UART interrupt number and priority */
#define UART_INTR_NUM        UART3_IRQ
#define UART_INTR_PRIORITY   (7U)
cy_stc_scb_uart_context_t UART0_context;
cy_stc_scb_uart_context_t UART3_context;
    .intrPriority = 7,
void UART_Isr(void)
	__enable_irq();
    cy_rslt_t result;
    /* Initialize the device and board peripherals */
    result = cybsp_init();
    if (result != CY_RSLT_SUCCESS)
        handle_error();
		/* Initialize SCB for UART operation */
		(void) Cy_SCB_UART_Init(SCB3, &UART3_config, &UART3_context);
		Cy_SCB_UART_Enable(SCB3);
		__enable_irq();
	//	Cy_SCB_UART_Put(SCB3,0x64);
    for (;;)
#if 0
    	//Cy_SCB_UART_PutArrayBlocking(SCB0, txBuffer, 3);
    	Cy_SCB_UART_Put(UART0_HW ,0x56);
    	/* Blocking wait for transfer completion */
    	while (!Cy_SCB_UART_IsTxComplete(UART0_HW))
#endif
#if 0
    	uint32_t rec_data;
    	if(Cy_SCB_UART_GetNumInRxFifo(SCB0) != 0ul)
    	rec_data = Cy_SCB_UART_Get(SCB0);
    	Cy_SCB_UART_Put(SCB0,rec_data);
      	uint32_t rec_data2;
        	if(Cy_SCB_UART_GetNumInRxFifo(SCB3) != 0ul)
        	rec_data2 = Cy_SCB_UART_Get(SCB3);
        	Cy_SCB_UART_Put(SCB3,rec_data2);
#endif
    	//Cy_SysLib_Delay(500);
/* [] END OF FILE */
謝謝,
零陵
0
Translation_Bot
嗨,
串口問題已解決,感謝您的耐心指導。 我還有另一個問題要問你,我該怎麼處理 ADC 的 DMA 中斷? 我想用 ADC 六個通道的 DMA 中斷讀取數據。
最好的問候
0
