06-27 14:44:48.991 0 0 I kernel: CFG80211-ERROR) wl_run_escan :  Escan set error (-16)
06-27 14:44:48.999 0 0 I kernel: CFG80211-ERROR) wl_run_escan : error (-16)
06-27 14:44:49.009 0 0 I kernel: CFG80211-ERROR) __wl_cfg80211_scan : Scan err = (-16), busy?-16
06-27 14:44:49.029 0 0 I kernel: CFG80211-ERROR) wl_cfg80211_scan :
06-27 14:44:49.034 0 0 W kernel: scan error (-16)
06-27 14:44:50.117 0 0 I kernel: CFG80211-ERROR) wl_run_escan :  Escan set error (-16)
06-27 14:44:50.125 0 0 I kernel: CFG80211-ERROR) wl_run_escan : error (-16)
06-27 14:44:50.132 0 0 I kernel: CFG80211-ERROR) __wl_cfg80211_scan : Scan err = (-16), busy?-16
06-27 14:44:50.141 0 0 I kernel: CFG80211-ERROR) wl_cfg80211_scan :
06-27 14:44:50.160 0 0 W kernel: scan error (-16)
06-27 14:44:51.230 0 0 I kernel: CFG80211-ERROR) wl_run_escan :  Escan set error (-16)
06-27 14:44:51.255 0 0 I kernel: CFG80211-ERROR) wl_run_escan : error (-16)
06-27 14:44:51.280 0 0 I kernel: CFG80211-ERROR) __wl_cfg80211_scan : Scan err = (-16), busy?-16
06-27 14:44:51.296 0 0 I kernel: CFG80211-ERROR) wl_cfg80211_scan :
06-27 14:44:51.302 0 0 W kernel: scan error (-16)
Roy_Liu
5 comments on KBA First comment on KBA 10 questions asked
This looks using a product that has not been released to the broad market, it is not supported here on the IoT community website. Please work with your local Cypress sales team that enabled you bring up using this product to line up the appropriate factory support.
Roy Liu
Roy_Liu
Roy Liu
