i have loading driver modules for my wifi AP6212(BRCM43430),when i ifconfig wlan0 up and start up the hostapd service i can find the hotpot, but when i running a application of video in and out to lcd with mcu of hisi3519v101, the hotpot will disappeared immediately. also i try to start up the application firstly and then to run hostapd, the log shows that the ap enabled,but i can't find hotpot neither. do some guys have the same exprience(my kernel is 3.18, and the wifi driver backports form 4.14.77, using brcm/brcmfmac43430-sdio.bin for chip 0x00a9a6(43430) rev 0x000001, Firmware version = wl0: May 2 2019 02:39:18 version 7.45.98.83 (r714225 CY) FWID 01-e539531f)?
the log is:
first: i run hostapd and then run the application ,
~ # ifconfig wlan0 192.168.1.1
IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
~ # hostapd -B /etc/wireless/hostapd.conf
Configuration file: /etc/wireless/hostapd.conf
wlan0: Could not connect to kernel driver
Using interface wlan0 with hwaddr 18:93:7f:36:36:0e and ssid "AP6212"
IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
wlan0: interface state UNINITIALIZED->ENABLED
wlan0: AP-ENABLED
here i can find the hotpot. then i run the application, the hotpot will disappear.
second: i run application and then run the hostapd,
~ # cd /modules
/modules # ./sample_venc &
/modules # station num = 17
[key_dev_set_irq 9]uv_irq_type = 2
[key_dev_set_irq 108]gpio_irq_type = 2
[key_dev_set_irq 109]gpio_irq_type = 2
[key_dev_set_irq 117]gpio_irq_type = 2
[key_dev_set_irq 8]gpio_irq_type = 2
============= MipiDev 0, SetMipiAttr enWDRMode: 0
SAMPLE_COMM_ISP_Sensor_Regiter_callback isp_dev = 0
Func: SAMPLE_COMM_ISP_Init, Line: 691, WDR Mode: 0
stPubAttr (0, 0, 1920, 1080, 30.000000)
linear mode
-------Sony IMX323 Sensor 1080p_30fps_raw12_cmos_37p125Mhz Initial OK!-------
Func: SAMPLE_COMM_ISP_Init, Line: 716 end IspDev:0.
ISP Dev 0 HI_MPI_ISP_Run
u32Width:240, u32Square:1
the bat_volume is 524 the bat_scale is 7
register cm :09 = val: e0630400
LCD initial end
/modules # hostapd -B /etc/wireless/hostapd.conf
wlan0: AP-ENABLED
/modules #
here i can't find the hotpot. even sometimes i will get some failure info when i run hostapd;
brcmfmac: brcmf_sdio_bus_rxctl: resumed on timeout
brcmfmac: brcmf_cfg80211_start_ap: SET SSID error (-110)
brcmfmac: brcmf_set_mpc: fail to set mpc
Failed to set beacon parameters
brcmfmac: brcmf_cfg80211_del_station: SCB_DEAUTHENTICATE_FOR_REASON failed -110
Interface initialization failed
wlan0: interface state UNINITIALIZED->DISABLED
wlan0: AP-DISABLED
wlan0: Unable to setup interface.
wlan0: interface state DISABLED->DISABLED
wlan0: AP-DISABLED
hostapd_free_hapd_data: Interface wlan0 wasn't started
nl80211: deinit ifname=wlan0 disabled_11b_rates=0
brcmfmac: brcmf_cfg80211_change_iface: WLC_SET_INFRA error (-110)
brcmfmac: brcmf_cfg80211_get_channel: chanspec failed (-110)
brcmfmac: brcmf_cfg80211_get_tx_power: error (-110)
brcmfmac: brcmf_cfg80211_get_tx_power: error (-512)
brcmfmac: _brcmf_set_multicast_list: Setting mcast_list failed, -110
brcmfmac: _brcmf_set_multicast_list: Setting allmulti failed, -110
brcmfmac: _brcmf_set_multicast_list: Setting BRCMF_C_SET_PROMISC failed, -110
thanks!
LINUX
Wireless MCU
- brcm43455
As chip down opportunities are not supported on the community, which BCM43430 (Broadcom PN) partner module are you using in your design?
Ampak AP6212 43430
