I wan to use IAR toolchain to build then wifi project , so my Make target is "snip.scan-BCM943362WCD6 IAR=1".However it take some Erro like the flowing
MAKEFILE MAKECMDGOALS=snip.scan-BCM943362WCD6 OTA2_SUPPORT is disabled
Building with IAR toolchain...
Building Bootloader
系统找不到指定的路径。
make.exe[3]: *** [build/waf.bootloader-NoOS-BCM943362WCD6/Modules/apps/waf/bootloader/bootloader.o] Error 1
make.exe[2]: *** [main_app] Error 2
make.exe[1]: *** [bootloader] Error 2
tools/makefiles/standard_platform_targets.mk:90: recipe for target 'bootloader' failed
Makefile:351: recipe for target 'main_app' failed
make: *** [main_app] Error 2
I couldn't solve this erro ,is there anyone who can help Me ?Thanks!!!!
Hello:
I just found we are now support 43364/43438 in the CHANGELOG.
* IAR Support (43364/43438)
* IAR build infrastructure support enabled in WICED
but if you really want to have a try based on 43362 , you can have an change on below :
1. you need to have a IAR embedded workbench already in your PC.
2. please create one folder and copy all the file from STM32F411 folder.
The folder name is STM32F415 , if you find some include errors, please change the directory as the error shows .
I am now can compile successfully .
