SDK 6.2.0
CYW43907
FreeRTOS + lwIP
I have been using wiced_tcp_send_packet without any issues until i tried to send larger packets. I then switched to wiced_tcp_send_buffer and it works great in an example application with no TLS but once TLS is added and the packet is large enough to be fragmented, I run into a data_abort exception. The best that I can tell, the problem occurs in wiced_tcpip_common.c, at line 213, during the free call.
if (enc_buf_allocated == WICED_TRUE)
free(enc_output_buf);
enc_output_buf = NULL;
Has anyone seen this?
The packet i was attempting to send was between 1800 and 1900 bytes.
- sdk 6.2
Have you tried increasing the packet pool size:
GLOBAL_DEFINES += TX_PACKET_POOL_SIZE=xx \
RX_PACKET_POOL_SIZE=xx \
WICED_TCP_TX_DEPTH_QUEUE=xx \
WICED_TCP_RX_DEPTH_QUEUE=xx
Choose xx to be a value greater then your current value.
