strac_4011406
First like given
Using Wiced Studio 6.1.  Running into a timeout condition using wiced_tcp_connect() with a 2000 ms timeout.  Looking for ideas on what the issue may be?
strac_4011406
First like given
Thanks for the wireshark suggestion, that helped and proved that I am sending out the TCP packet and that it is the "other" end that  has the problem.
ChMa_3922746
10 likes received 10 likes given 5 likes given
You could try running Wireshark and see what's happening on the network.
RaktimR_11
500 replies posted 250 replies posted 100 replies posted
Could you please mention in what situation you are facing this error; i.e what is the application etc and also try capturing the wireshark log as already suggested?
strac_4011406
First like given
