harelTur
25 sign-ins 10 replies posted 10 questions asked
Hi
I use cypress 4343A1 (Laird EWB )
I use OS - Thredex.
When I try to create/init queue by API wiced_rtos_init_queue
I get return code 04 (WICED_ERROR).
Please let me know what the problem
HarelT
Murali_R
250 sign-ins 250 replies posted 100 solutions authored
@harelTur The return code 4 indicates a WICED_ERROR which in this case, I think is being caused by the sizeof(RPT_HeartBeat_t) not being a multiple of 4.
Change this size to a multiple of 4 and the issue should get fixed.
Murali_R
Can you have a look at the code example here https://github.com/Infineon/CypressAcademy_WICED_WiFi101_Files/tree/master/Projects/ww101key/03 and check if it guides you in resolving your issue.
If not, please attach your code here and i'll take a look at it.
harelTur
RPT_LOG_DEBUG_MSG("RPT: wiced_rtos_init_queue(HB_Queue)...\n");
wiced_static_assert(Queue_element_size_must_be_GE_than_int, sizeof(RPT_HeartBeat_t) >= sizeof(int) );
wiced_static_assert(Queue_element_size_must_be_a_multiple_of_int, (sizeof(RPT_HeartBeat_t)%sizeof(int)) == 0);
RPT_LOG_DEBUG_MSG("HB_Queue Queue size %d\n", RPT_HEART_BEAT_QUEUE_SIZE);
res = wiced_rtos_init_queue(&RPT_HeartBeatQueue, "HB_Queue", sizeof(RPT_HeartBeat_t), RPT_HEART_BEAT_QUEUE_SIZE);
This is my code/
It can be involve to stack ? why the return code is 4?
Harel
Murali_R
