Hello.
I'm using CYW943907AEVAL1F.
I load "snip/sd_filesystem" code.
I put on uSD receptacle this model of uSD Scheda MicroSD PRO Endurance - 2018 (128GB) | Samsung IT
This uSD is a 128GB, interface UHS-I, Class 10.
Line 375 of "sd_filesystem.c" calls "wiced_filesystem_mount .. WICED_FILESYSTEM_HANDLE_FILEX" fails.
I dont' understand, in datasheet "002-14829 Rev. *K" page 18 I read UHS-I modes are supported.
WICED Studio Wi-Fi Combo
NTFS is a proprietary FS from Microsoft and you would need to check with them if it can be added to an embedded device.
Can you look at this blog post and see if it helps https://community.cypress.com/t5/Resource-Library/snip-sd-filesystem-Application-in-Wiced-Studio/ta-...
There was similar issue faced here : https://community.cypress.com/t5/WICED-Studio-Wi-Fi-Combo/filesystem-mounting-error-of-quot-snip-sd-...
Let me know if this helps.
According to ...
I write
USING_FILEX:=yes
in *.mk
(GLOABLE_DEFINES += FX_ENABLE_EXFAT was already disabled)
... but no results ...
I try to change formatting type from exFAT to NTFS but nothing
