Every once in a while, calling wiced_bt_smartbridge_connect causes my board to hang indefinitely. The rarity of this makes me think it could have something to do with the internal state of the bt_smartbridge code. Has anyone ever seen this? Is there some delay between attempting connections or attempting connections and scanning?
I do check that wiced_bt_smartbridge_is_ready_to_connect() == WICED_TRUE immediately before attempting the connection, but that doesn't seem to make a difference (unsurprising, since the connection routine performs this check).
I'm using sdk 3.1.1
SDK 3.x
Wifi+Bluetooth
Is this still an issue. If so what is the evaluation board are you using?
Seyhan
I don't think it is an issue any more. I think it had to do with creating too many threads? It seems to have gone away now that I have consolidated some of them.
