Wi-Fi Combo Forum Discussions
I am using wiced studio 4.1.0.I can able to download and run the demo applications.
However, I got some errors when I tried to use the GDB debugger.
I used this make target: test.console-BCMUSI22.A1-debug download
I have made some changes in the debug configuration .I have attached the screen shot of the changes made.
But still I am getting error like 0x0800c6ea in _start ().
It is looping into GCC file instead of main application.
Can anyone help me how to setup the debug environment and remove the errors.
PriyaM_16
25 solutions authored 10 solutions authored 5 solutions authored
Kindly follow the settings given in the attached document for debug configurations.
Have you solved this problem? I have the same problem. And I am thinking if we should open a GDBServer using openocd. Because I have using the GDB debug on STM32, it should have open GDBServer.
PriyaM_16
