The version of SDK is 3.1.2
To test the https_server i need to modify the CLIENT_AP_SSID/CLIENT_AP_PASSPHRASE Wi-Fi credentials in the wifi_config_dct.h header file, but there is no this header file under the https_server folder.
Quesitions:
1. I want to think which wifi_config_dct.h header file is used for the project of https_server.
2. And there are several projects such as tcp_client, tcp_server and so on. there are no this header file under each folder too. Are they treated as the same way.
3. If i want to add the wifi_config_dct.h header file to each project, what should i do?
Looking forward to your reply!
Thank you!
All the best wiches for you !
SDK 3.x
softAP
Web Services
If WIFI_CONFIG_DCT_H is not set in the application's makefile,
default is using include/default_wifi_config_dct.h.
Thank you very much!
