when I use then mode ---WWD_DIRECT_RESOURCES-- ,how can I confirm the address of firmware ?
could you tell Me the difference about the tow mode(download firmware )?
Wi-Fi Direct
Wireless MCU
Hello:
WWD_DIRECT_RESOURCES : the firmware is compiled into app image, below is the address.
RESOURCES_IN_WICEDDFS: means there has a filesystem image to store the firmware.
In current release you need to comment the define at line 44 in the BCM943362WCD6.mk, then you can see the difference when you tried to change the define.
Hello:
