I'm trying to use the config_mode snip as a pattern for my own application.  However, I'm not having much success.  I can serve up some of the files but I must be missing a script or something because the scan never happens.
I can't see where the resource files are getting set up in the config_mode snip.  In other examples, such as apsta, there is a "START_OF_HTTP_PAGE_DATABASE" in the .c file with a list of files.  Also there is usually a list of file names in the $(NAME)_RESOURCE sections of the .mk file.  The config_mode example has neither of these.  How does the compiler know what to include?
The .c files with the functions and HTTP page database are in Wiced-SDK/Wiced/internal, named config.c and config_http_contect.c.
The make file that includes the resources should be in the Wiced-SDK/Wiced folder as Wiced.mk.
Thanks, I found the remaining information in Wiced/internal/config_http_content.c
