hi,
I'm new here and would appreciate some good advice on how to download and debug the FW on sn8200.
from reading the forum i have learned the following steps are needed:
build using BCM943362WCD2-debug download JTAG=jlink
so far I always get the **** OpenOCD failed - ...
jlink is installed correctly and works fine in IAR.
Martin
The WICED-SDK does not come with the platform files for the Murata SN8200.
Murata should be able to provide you with the appropriate platform files. I believe you can send your queries to modules@murata.com.
There is a patch file available on the Murata portal for the SN8200.  Please register with your EVK registration code at www.murata-ws.com.
Thank you, Paul
