Hi
This was reason of one of my problem , and I have mentioned this in another thread but didn't got a valid reply, so re-posting again.
When I use debug / run along with the build string for compiling and downloading a sample application causes the WiFi throughput to be very low.
How I measured this was when I used udp_transmit app
snip.udp_transmit-SN8000x-FreeRTOS-LwIP-debug download ,
I observed that the UDP packet creation+sending takes 8 milliseconds (same with download run also), But when I changed the build string to
snip.udp_transmit-SN8000x-FreeRTOS-LwIP download
The UDP packet creation+sending takes only about 400 microseconds.
This indicates a severe performance degradation while using debug or run in the build string.
What causes this behavior ?
