update the local time
Hello sir,
     We are working on wiced module and use SDK 3.1.2 stack. i getting the GMT time and it is update every 10sec and using this i get the country time by adding or subtracting the offset value.
I need the local time of country directly through internet. Is it any way possible ?
waiting for your reply..
VikramR_26
25 sign-ins 10 sign-ins 10 comments on KBA
Yes its true, another alternative is to use REST api and get time from websites like TimeAPI or API Access for Developers - TimeZoneDB
VikramR_26
Did you check the api called sntp_get_time()
AxLi_1746341
Level 7
Level 7
10 comments on KBA 5 comments on KBA First comment on KBA
WICED SDK does not provide APIs converting UTC/GMT time to local time zone.
You need to implement it by yourself.
VikramR_26
hello sir,
Thank you very much.
I already get the GMT time using sntp_get_time(). I have an idea for the GMT time conversion to local time.
have you idea for getting the local time automatically(using API) ?
Once again thank you very much.....
