I am trying to determine a Wiced Wifi module that has Wiced SDK support and is purchasable via digikey / mouser / avnet / arrow
The ones I have checked are all out of stock. Can you please share your module suggestions?
thanks
WICED Studio
Hi riforifo,
If you are looking for only WiFi functionality, you can go for chip CYW43362, modules by our partner Lantronix and Murata. Here is the link of list: http://www.cypress.com/products/wi-fi
If you are looking for WiFi-BT combo chip (BCM4343W/CYW4343W is a combo chip), we have modules Type 1LD, Type 1MD and others from Murata with chips CYW43438/ CYW443W. You can refer http://www.cypress.com/products/wi-fi-bluetooth-combos
Here you can find the links to purchase particular module: Purchase a WICED Wi-Fi Dev Kit
All of our partner modules are listed here in the IoT Solutions Guide
Please tell us more about your WiFi and Bluetooth Modules needs and we can then recommend a module partner.
I used AES-BCM4343W-M1-G (from Avnet) previously but they are out of stock. Basically I simply need Wifi, uart, spi, i2c and OTA capability.
I plan to use the module in a iot gateway design.
It shouldn't be too expensive and it would be nice if I can simply purchase it via digikey, mouser, avnet ...
Hi riforifo,
hello,
thanks for the answer but 50 - 200$ price range is to high. Aren't there cheaper versions?
AES-BCM4343W-M1-G (from Avnet) costed around 19$. Aren't there similar price range modules that you know of.
thanks
That price range was a mistake. I believe SheetalJ_96
was quoting evaluation board pricing. Simple b/g/n WiFi only will cost quite a bit less than what you quoted for the Avnet module.
For the best pricing, I'd recommend engaging directly with one of our global distributors like Arrow or Avnet as online prices are often higher than the negotiated pricing you can obtain working directly with a distributor.
